86/93 jeep cherokee
tuffkiller
toledo,ohio
The jeep is an 86 that I put a 93 I6 motor and tranny. It has 2" rubican express lift. spacers in front blocks in rear. It has new coil springs up front and a new extra aal for the rear also will come with it. Posi loc for the front axle. Dash and trim from 86, 93 gauges. It has an auto tranny. Gas tank was switched, for the fuel pump. All wiring was carefully removed from donor jeep, that was a daily driver. Jeep is 80-90% done. It did crank over but didnt fire. The motor ran fine when pulled with 127,000 mi. Tranny worked great. Cant garuntee the 231 tcase since I bought it and never used it. Its clean and shifts fine. The jeep had a rot hole in driver and pass floor which has new panels in. I had to cut some of the tranny hump out to fit it so that still needs a cover panel. The front was cut to fit the 4.0 radiator. Id like $500 for the whole thing or trade for big car to run in a demolition derby. Other trades welcome. I will be posting pic in a day or two. Email me at [email protected]
