8 lug hp d44 to 8lug or...
ZachMan
NAXJA Memorial Lifetime Member
Birmingham, AL
Well looks like I may be getting a built 8 lug d44, but the issue is its 8 lug. I wandering the easiest way to get it to 5 on 5.5? Only reason I ask is I have a rear 9" I want to use.
I'm pretty sure that you can use a 6 lug spindle (any early 1/2 ton chevy or ford d44), knuckle and brakes.
I happen to have an extra set of ford knuckles, spindles and lock outs.
Let me know if you are interested.
The knuckles are off a 70's model ford supercab 1/2 d44 (could possibly be used for high steer).
I got these to run high steer and then I found a set of chevy FTK's so I won't be using the ford stuff.
They have calipers, and dust sheilds although the shields are pretty beat up and I do not know the condition of the calipers but you could use them as cores. $150 plus shipping if you are interested.
Well I may just go aftermarket knuckles and the axle is already high steer (reuse the arm). So besides that I need spindles and new hubs? The warn hubs on it now won't work?
Or are aftermarket knuckles a waste on a d44? even though its the thicker hp d44?
the aftermarket knuckles were just too much $$$ for me...
I know the 8 lug 3/4 ton spindle with not work with the 1/2 ton 5 x5.5 kunckle so you will need to go to the 6 bolt spindle which is the same on most of the 1/2 ton chevy and ford d44's.
The 3/4 ton spindle is a 8 bolt (i think) and the 1/2 ton is 6 bolts...that is why you'll need the spindles as well.
I'm not sure about the hubs...the ones you have should work...i think.
Think I'll be going d60 rear.
