You can get used 29 spline shafts or new shafts, replace the side gears with ones for a 29 spline axle. The other option is to purchase a PowerTrax No-Slip locker and install it to replace the spider and side gears. This will provide you with the increase in axle strength up to 33" tires or 35" if you are gentle on the skinny pedal.
