8.25 axle shaft conversion
yes.
if your replacing the carrier and the shafts to 29 spline, it will fit right in.
Jeffro600 said:
Does it fit right in, or does it need modification??
IIRC you need to change the seals though right? Someone with more expreience on this may have more insight but the shaft dia. is different.
The shaft diameter at the bearing and seal is the same.
