As of tonight the new head is on! I did end up using the donor head bolts, and I highly doubt I will run into any issues because of that. It took a while, but all the pushrods, rocker arms and their associated parts are in and torqued down, and heavily oiled (Jeep is going to be sitting for a while longer, most of the oil I am sure will drain back into the block...) the local parts store had to order in the valve cover gasket, but I didn't want stuff getting in the head, so I just put a few layers of masking tape on the gasket seat of the valve cover, and lightly bolted it in place for now and taped off the top holes. Wednesdays plans are to get the exhaust headers installed, and the new intake manifold and power steering pump, and probably get the new alternator in and wired up, then of course get the gasket and all the ordered parts in... Will post some pictures once we get more done on it!
Thanks again for the help guys!
Paint
