Paintballpsyco2369
- Memphis, Mi
Well, it seems after some more digging and Jeep build progress, I have the opportunity to upgrade the head on my Jeep. I have the engine halfway to a head gasket change with all the upgrades I am doing, and figure I am this close, I might as well go a head and change the gasket, and since the old head will be off, go a head and replace it with a newer one. This actually makes things a TON easier with my intake and exhaust upgrades too, which are already thought out and good to go.
Pertinent info: starting with an 88 4.0 rig, and needing a donor 91-95 4.0 head with #7120 casting.
So here is the dilemma though, for the donor head I have 2 options:
- Option 1: I found a local one for $60, for just the head and valves, no rocker arms, push rods, or the caps, pivots and bolts for the rocker arms. Also no valve cover, so I am left to either re-use what I have now (old and possibly non-useable) or replace it with all new stuff, exception being the valve cover, I am pretty sure mine will work. It is less than 100k, and looks to be pretty clean as it sits, and looks pretty good actually, and I know it came off a good running motor.
- Option 2: I called around to some local yards and found one at a you-pull for the same price, $60 complete, so I know from that I can get all those other parts and re-use them, except for maybe the push rods, if not too expensive I might just replace them since that is the only "between block and head" part that is not staying with it's original engine. I also know they will probably let me take the valve cover with it, and the thermostat housing without issue, and all the other bolts that go to this "new" setup. The ONLY downsides here, all I will know about the donor rig is what is written on the windshield, and the odometer, and I DO run the risk of finding the head cracked or damaged once I get it off, or other components therefore wasting my time, and possibly money if I find out later. Then of course taking the time to do all this more than likely by myself (most of my friends are unable to help with something like this) so it may take a while...
Any ideas on which option would be better here?
And one more question, as for head bolts, I am more than likely going to replace them as cost isn't TOO bad and since I don't know this history of the donor rigs (assuming I trust the PO did the paint thing if they re-used them) and my rig is 24 years old (assuming everything is factory still) and has quite a few miles, should I get a set of Renix head bolts, or the head bolts corresponding to whatever donor rig I get the head from?
Thanks greatly in advance for any help you can provide, hoping to get these parts by this weekend so I can start putting my engine back together...
Paint
Paint
