sardo_67
- western CT
Because 325 / 365 just isn't enough...
Uhhh why would it be? Hahah.
I won't be happy with mine till I'm over 500 at the wheels.
No such thing as too much horsepower, only too little traction.
Thank you everyone for the compliments and support throughout this build. I truly believe we have the best Jeepers out there on this forum!
Jeremy
How have the stock gauges been working? Did you use Novak's tachometer module? Are you powering the speedometer using the output from the GM PCM?
Right now it has 32s and a 4" with the stock 3.55s. My plans is to run 35s. My last Heep had everything up to 37s, and I was the happiest with 35s. As for the axles and lift, its still up in the air, but I'm thinking Ford 9s, 6" lift and 4.56s.
Sounds about right. 9" in the rear too with that low pinion?
