Vintage Smoke
- Wantage, NJ
the GM transfer cases use 6 bolt pattern but it is not the same pattern like Jeep TC. You just need a adapter and other input shaft to match the Jeep TC to GM trans. I and some guys from here use the NP231J behind 4L60E without problems.
I would suggest beefing the NP231 (6 planetery gears, thicker chain) or use the GM NP231C (has already thicker chainh..) or NV241 TC.
I switched the input shaft from NV246 (originaly behind 4L60) and the planetary set
Its not what trans its behind....its the 6.0 which is a seriously torquey motor. Driven cautiously the 231 will be fine. With the upgraded planetary, chain, etc, it will be better, but in my opinion whats the sense of going big on the motor if every time you hammer down you are worried about the weak link which is the transfer case. Axles can always be upgraded later as money allows or if you break them without disturbing the rest of the drivetrain, but since the transfer case requires custom adapters, mounts, cross members, upgraded parts, shift linkages, etc to install why not start with a stronger case the first time and do it once? Again...just my opinion. Everyone's needs, budget, expectations, etc will vary.
