KDUBXJ
- Salt Lake City, Ut
This a newly built bottom end professionally built by Pro Machine Machine shop. No Head. I do have high performance oil pump and push rods that go with it. It has never been run. 95 HO TJ block, 89 Jeep 4.2 polished crank. Rods from the same 89 engine. Comp 4x4 High Performance Cam, Block has been bored over, honed, hot tanked, measured and built right. New pistons, clevite bearings, rings, freeze plugs, crank seals, etc. Engine will be capable of over 300 hp easy when built. Not going to finish the project. Spent over 1200 pm on the build so far.
