600 miles on it so far. Changed the oil using Vavoline VR1 10w30. Engine is still running great, no complaints on that side. That S&B intake has a mean growl at WOT, a lot better than the Rusty's air tube I was running.
I was chasing a header gasket leak for a bit, but it wasn't actually leaking... the flex plate has a crack near the crank... will be pulling the tranny soon. I inspected it pretty well and never saw a crack when I was installing it. And I know I looked. Getting a bit tired of taking it apart... can't I just drive it? This would make sense since the transmission and the roof rack are the only items that I haven't removed yet.
Finally got my injectors installed. Reset the PCM and it starts better and seems to have a bit more pep. The injectors ordeal was fun. Bought one set of the Ford Cobras off ebay ($60 for 8), installed them. It didn't even start with them. Called the company back and they sent me another batch. From the smell of what use to be gas I decided to send them to be cleaned and didn't even try to install them. The company that cleaned them said that all but one were stuck closed.. the other one was stuck open. He cleaned them ($130 for 8) and they are flowing within 2% of each other. Still cheaper than buying new ones and I have two extra and a second set that needs to be cleaned to work.
On another note my exhaust was like swiss cheese. One shop installed my cat back, another installed the cat and yet another welded the header to down pipe adapter in... all had leaks.
