Almost completed:
Done and done:
Custom S&B intake, which I would NOT recommend/ Without modifying it the hood wouldn't even close. I had to redrill the air box to clear the radiator cap, cut the flange where the tube meets the throttle body, and cut the silicon gasket form the throttle body to the tube. And I just bought it because it had an enclosed box which I could further enclose to the front. At least it was only $99.
Its fast, but I am not pushing it much now. I want it to break in then tune it then push it. The exhaust sounds good. A little valve noise is audible, but I am use to that. I may have an exhaust leak someplace.. not sure yet. If so its not very large.
Now to just getting use to driving it again. The ZJ isn't quite as still in the suspension nor the steering department, nor are the breaks as good nor is it as fast.
I will be putting some miles on it and hopefully this one will hold up better that the Titan 4.Fail.
I still have a few minor things to do: install the new push rods (correct length so I can take out the shims), clean up some wiring, relocate the IAT to the air box, modify the air box more so it gets more cold air, check the transmission fluid, eventually change the coolant, take care of that lean part (larger injectors? just run the apexi? have the computer tune changed?), play with the spark plugs (different heat range maybe? change gap?) and get rid of that damn coil rail... probably more things that I can't remember at the moment.
Now I just need to clean the storage unit up a bit, put away.find some missing tools and sort the pile of crap in the back (boxes, spare parts, parts from the previous stroker, etc).
-Chris
