PumpinIron
- Portland, OR
That's what I was thinking. 4.56 for 31" tires just seems a bit too extreme. I'm also not towing hardly ever and when I am it's just a dirt bike so nothing heavy at all.
Odd, my experience is the complete opposite x 10+.
And an "easy" tire size swap to compensate for the wrong gearing selection costs what?
hasta
4.56s on 31s is what i should have run. I went 4.10s first thing when i was still bone stock because they were cheap to do and i was planning to step up to 33s (was running 235/75 at the time). the initial setup of 29s on 4.10s was my favorite by far. CA grades were a breeze and i got my best mpg of 13.5 city and 19 hwy. then 31s came and while tolerable its just not the same. Hills took a little more work but it still could cruise in OD on flat land just fine. MPG dropped slightly in the city and was about 16-17 on the freeway depending on load and how many hills i climbed.
I'm now on 33s, but i wont go into that since 31s are the topic here. With that said i would spring for 4.56 for 31s in a heart beat. the higher rpms are really not an issue for the 4.0 and if you are really loaded down you will see better mpg with the 4.56 vs. 4.10s. i really miss running 29s on 4.10s haha
To the OP, my xj (auto, 4L) spins 2600 rpm at 65 mph. That is with 31's all terrain tires and 4.56 gears. If it is important to you that you cruise on the highway at 75 mph go with the 4.10 ratio. Otherwise reap the benefits that the deeper (456) gears provide (more low end torque, better towing, better crawl offroad).
This, and more.what mileage do you get at that?
2600 is no problem all day
Now, they don't mind idling around on the trail all day and have no problem doing so. On the highway, let 'em wind. Just not at like 4000RPM - then you'll deposit lots of piston skirts in the pan.
What makes you think that?
For some reason, once you start hitting above 4000 repeatedly, they let go. The only 4.0s and 2.5s I have seen pop ( in person ) was when someone held them at the red line a bit too long.
Unless you're running like 23'' car tires, I don't think it's possible gear it low enough to be at a sustained 4000RPM on the highway haha.
We've held our motor over 4,000 RPM for 4+ hours at a time. Hasn't blown yet..
