4.0 swap
garciaxj88
yuma,arizona
alright here is the deal. i have an 88 xj with the renix 4.0. i dont really like the renix system because there is little support from the aftermarket. im planning on building a stroker 4.6 but i wanna use the high out put setup. so my question is what will i need to convert the renix to high output? besides the high output PCM, and wiring harness. what can i still retain from the renix system? what about the TCM? can i still use the renix one or do i have to swap that 2? more than likely ill buy a donor vehicle to do the swap.
