I think the whole no lift or minimal lift and 33's is a GREAT Idea...there is alot of room to cut and fold on these things. The only thing I would see being a problem is ground clearance, departure angles, and approach angles. which will only make you pick better lines in the trails and become, in a sense, a better driver. I have driven stockers, budget boosted, and lifted heeps on local trails and other than the problems listed above, the stocker will go anywhere a lifted one will.
Me personally, I dont like the wheel and spacer combo...but it's like "hey use what's cheap." The combo is a bad idea because it puts a lot of strain on the outer axle components.
keep up the good work...go wheelin with us..ttyl
