33" BFG AT's
XJ_ranger
Port Orchard, WA
Hey,
I got 6 tires.
3 are in perfect running condition, hold air, no plugs, good tread
1 good tread, 2 sidewall cuts with plugs, slow leak, good for trail spair
1 decent tread, was used as spare till sidewall cuts, id use it as a road/trail spare, or run it for another 10k miles without worry.
1 tire with some tread left, 1 professionally installed plug in the tread, hold air, is my spare.
5 of them are on 15x8, 5 on 5.5, some backspacing, steel rims with some dents/rash. all hold air at street pressure. the most bent of them has a tendancy to burp air at low pressure, but that could be the spare rim.
the sidewall plug tire is loose.
hows $230 sound? $200 if you're a member? offer?
Pictures of the tires perhaps?
Clayton, OK - 5/2006
Fordyce Creek - 6/2006
Rubicon, 6/2006
Stoddard Valley - 8/2006
JV this 11/2006 - they havent changed any since then, as all ive done is pull them off the rig...
PM me if you're interested...
Located in Benicia, CA, can transport anywhere in Bay Area / Fresno / Reno for a nominal 2 liter of coke and a good conversation fee :D
