BoringDave
- Boring
Heck after reading this I may go with 31's and 488's. The only time I hwy drive is when I am pulling a 23' travel trailer and then I never get over 55mph.
Dave
Dave
No, don't start another locker thread, read the ones already here...Thanks guys, you've pretty much validated my thinking. I may even move up in tire size as early as this fall, so it might not be a whole year. My main focus for this summer, however, is reliability.
Now, do I dare start another locker thread? I'm thinking Powertrax, but I have some reservations about winter driving. opinions?
can i say ur all nuts with ur over gearing way past stock performance. use http://www.therangerstation.com/tech_library/Gear_Tire_RatioChange.html. to the OP if u drive a manual ur going to be massively over geared at 4.56s and 31s if ur an auto u wont be quite as bad but still over geared.
I run 33s and 4.88s. On the highway I turn about 2500-2700ish rpms at 70-75. I see no need to go faster than that and the engine handles those rpms just fine.
You want to be deeper than stock. Run stock gearing and tires with about 500 extra pounds of gear in it and see what impact it has on your performance. An XJ with bigger tires has to overcome more than gearing with the larger rolling radius of the tires. Rotational inertia plays a big role in negatively impacting your "power". Bigger tires weigh more and that weight is at the end of a longer lever (radius), therefore one extra pound of tire/wheel weight has a larger impact than 1 extra pound of Jeep weight.can i say ur all nuts with ur over gearing way past stock performance. use http://www.therangerstation.com/tech_library/Gear_Tire_RatioChange.html. to the OP if u drive a manual ur going to be massively over geared at 4.56s and 31s if ur an auto u wont be quite as bad but still over geared.
You're misunderstanding what rotational inertia is. Regearing to be comparable to stock will be regearing to move the stock rotating mass. Our rotating mass is much heavier than stock as well as taller, thereby acting like a much larger increase in overall vehicle weight. Why do sports cars, race cars and drag cars go with the lightest wheels possible before removing weight from the rest of the car? Because removing rotating mass, thereby decreasing rotational inertia, has a much larger impact on performance than shaving the same weight from the vehicle itself.
Normally, you're looking for the moment of the mass. That would be mass of the body multiplied by the radius. But in this case, both masses have equal distribution so we can use the ratio of masses as a guide. The ratio is .75, so the lighter wheel will be 25% easier to spin.
[For nonbelievers we'll go through the physics...
We have 75% of the weight at a radius of 8.5 inches. and 25% of the mass "in the center". Well, we'll still need a radius for this mass, so let's use the bolt radius or about 2.5 inches. Hopefully that will be OK with everyone. So the equation for the moment of the wheels would be:
moment (in pound-inches) = .25mass(2.5inches) + .75mass(8.5inches)
Moment for the heavier rim = 168 pound-inches
Moment for the lighter rim = 126 pound-inches
There, the ratio of the moments is the same as the ratio of the weights.]
We all remember F=ma. Force equals mass multiplied by acceleration. In angular terms;
Force equals moment multiplied by angular acceleration. This is a direct relationship. The amount of force needed varies directly with the magnitude of the moment.
So... the 18 pound rim will accelerate the same as the 24 pound rim using 25% less force.
But aww shucks it doesn't matter a hoot, because we're spinning more than just the rim. The rotational mass on our cars consists of far more than just the rim. It's the hub, the break disc... heck, on the rear wheels we even have the axle, differential and drive shaft!!
And let's not forget the tires themselves!!!Assuming the tire weighs about 20 pounds and the center of mass is at 12 inches, the moment would be 240 pound-inches, far more than either rim.![]()
When all of these moments are averaged in, the 25% advantage quickly gets "lost in the sauce" of the entire rotational system and any difference in rim weight is truly inconsequential, really.
In fact, the weight reduction would matter much more for linear acceleration purposes. Considering a 3000 pound vehicle, a reduction of 24 pounds gives you almost a 1% increase in acceleration. The differences in angular acceleration for the lighter rims is far, far smaller than that.
As others have said, the main benefit is in unsprung weight. A lighter wheel, will allow the suspension system to react faster to changes in the road, resulting in better handling. When considering unsprung weight, we're again talking about linear acceleration. We no longer worry about moments, so the tire will not dominate the equation as it does with angular acceleration. Also, only about half the mass of the axle will be involved and none of the drive shaft or other rotational masses of the system.
So... reduce the weight of the rims for handling purposes and not for any other reason. Well... maybe cosmetics.![]()
If drag racing is your bag, you'd want to reduce every pound for linear acceleration purposes primarily.
Except that post is isolating the weight difference in the wheel itself. We are referring to the wheel and tire combo. They argue that the extra weight of the tire cancels out any small differences in wheel weight.Post #12 confirms what I said about the mass of bigger tires not mattering much
http://www.solsticeforum.com/forum/f11/rotational-inertia-energy-42639/
