I installed a Taurus radiator fan in my '89 4.0L this past summer and I didn't have a toggle switch for it, it was just always on. Well tonight I changed that. I don't have AC so I don't know how you would incorporate it with the AC override, and it's a RENIX era rig so the later models wouldn't work, but I figured I'd share it anyways.
For the switch, I grabbed a 3-way rear-wiper switch from another XJ in the junkyard. I popped the front off of it, took the spring out, and it acted exactly like a proper 3-way. Up, middle, and down. This creates the selections: Auto - Off - On
Using the auto selection takes advantage of the stock switch in the rad. Off is off, and on is on all the time.
And the diagram! (The top right S is the radiator switch)
Basically you splice into the yellow wire, and split the grey wire into going into the 3-way rocker switch. The wires are down near the rad-switch. I'm not sure if it actually ends up going to the relay like pictured, but I just used that as a reference.
I hope this helps someone.
