But i'm sure there is no stock Dana 30JnJ said:Not true, plenty of folks here run only one upper.
XJoachim said:But i'm sure there is no stock Dana 30![]()
brent said:one upper arm isn't enough to controll your axle wrap in the front, don't do it.
Be careful, though. While easier to do, adding the top link to the passeneger side of a driver's side drop axle has the potential for a much more drastic pinion angle when the driver's side droops and the passenger side is compressed. You won't experience this nearly as much (if at all) with the top link on the driver's side.
Thems some purdy blue knuckles you got.
Beezil said:I figure I'm safe posting those pictures since one ton got goofey with yellow paint on his.....
Beezil said:Cresso, this isn't correct. Remember this is a discussion on radius arms, which is a completely different animal than the quad link per stock.
The axle is rigid, it does not matter where you put the upper, as long as it is strong enough to resist.
if some of you guys are having trouble visualizing the geometry and the movement, build a simple model.
the lowers position the axle underneath the vehicle to maintain wheelbase position. The tracbar keeps the axle positioned under the vehicle (left-to-right) as it pivots in an arc centered on the frame mount on a radius relative to the length of the link to its axle mount. the single upper has a simple task of keeping the axle from rotating in relation to the lower arm arc.
The lower radius arms have ONE CENTERPOINT of arc movement. This is different than the stock quad link that has TWO centerpoints of arc. the upper link on a radius set-up does not go to a different point on the 'frame'. It ties into the lower arm.
the axle CANNOT TWIST AS LONG AS ONE UPPER (OR TWO) REMAIN FIXED.
Ary'01XJ said:Mark, do you have any shots of the rear of the axle? I'm trying to figure out what you got goin on and I don't quite get it. It almost looks like you're just running 3 short arms, yes no? It also looks like you inboarded the LCAs makin the angles steeper. Thanks
Ary
Cresso said:Large tie rod ends.
