YFZsandrider
- Pacific NW
I recently bought a '98 XJ with 144k miles. It has D30 front and 8.25 limited slip rear. The previous owner installed a 3" Old Man Emu lift about 10-12 yrs ago, and maybe 80k miles ago. It has 31x10.50 A/Ts with quite a bit of age, but still usable tread on them.
This is my first Jeep, so I'm not too sure what to expect out of it, in terms of road manners. It seems to do fairly well, considering the lift, but does leave a little to be desired in the daily driver department. It also has a bit of the 50mph front end wobble.
Ive read alot of the tech regarding 31's being the largest size without much modification needed to the supporting drivetrain, But before I plop down cash on some new tires, I want to make sure I should jump to 33's in size.
Ideally, I'd like to stick with 31's and avoid regearing it, but how much offroad capability can be had out of a short arm setup with my current tire size?
So a few questions...
-Should I consider aftermarket control arms with heim joints?
-Should I freshen up the suspension by going through the ball joints, maybe new shocks?
-I'm assuming the suspension is stock besides the OME lift, so I don't know whats going on with my track bar and steering, whether its stock, if it should be upgraded, etc?
-Where should I start on this, keeping in mind that I've got some money to spend on it, but would rather go the route of getting as much offroad capability as I can out of the current lift it already has.
-Should I get sway bar disconnects, new tires, and trim the fenders a little?
Where should I start?? All advice is welcome, thanks guys!!
