smccollamjr
- WV
No matter how much prep and PB Blasting you do, I’d have a plan b for work Monday morning. There’s always that one thing you weren’t expecting. Good luck, XJs are a ton of fun.
I did the RE 3.5 last year in mine. You can get the kits with track bar, different shock packages etc. I did the short arm super ride setup with quick disconnects also. You will probably need a SYE also. I have been very happy with mine and my use is similar to what you described.
Is it common consensus that an SYE is necessary for a 3.5in lift?
I was hoping if I kept it at 4in or lower I could avoid that extra cost.
What say ye?
