3/4 axles, deavers, 9100s...
XJLI
Long Island, NY
8 lug front HP44 from a 78 F250
5.13 gears
OX locker
nitro inner and outer alloy shafts with spicer 760 ujoints
full truss, inner Cs braced, mix of ballistic, ruff stuff, rock krawler, and custom mounts
all new brakes (dual piston), bearings, seals, ball joints, etc
warn lockouts
crossover steering with 1 ton tie rod ends
custom trackbar with ruffstuff heims
parts mike high steer arm on pass side for crossover steering
1310 ubolt-style yoke
needs a new pass side knuckle and upper ball joint to be complete
BOLT IN to any XJ/MJ/TJ/ZJ/WJ
$3500
rear D60-ISU
8 lug dana 60 from a late 90s E350
ruff stuff axle swap kit- ubolts, antiwrap leaf perches.
ballistic truss and oversize diff cover (for link mounts)
5.13 gears
lock right locker
35 spline chromo shafts
brand new disc brake setup
BOLT IN to a XJ/MJ (spring over)
$1200
rock krawler four link upgrade kit for a XJ $900
deaver 5.5" jeepspeed coils - $250
deaver 4.5" jeepspeed leafs - $800
JKS 1" lift boomerang shackle - $90
RE 1.5" lift boomerang shackle - $90
custom built & valved bilstein 9100 shocks:
10" travel 2.5 remote resi, weld top, valved for the front of this rig - $525
12" travel 2.0 remote resi, threaded for coilover hardware, valved for the rear of this rig - $475
rear prothane progressive poly bumpstops - $50
front prothane coil inserts, 8 rings tall - $50
35x12.50 BFG ATs with 40-50% tread mounted on 3rd gen dodge 17" steelies painted metallic gray.. 8 lug, ~5.25" BS - $400
prices may or may not be neg depending on the part.
Negotiable on the bumpstops and coil inserts?
