daredevil
- Beaverton, OR
I was curious to know...I found a sweet deal on a 2001 XJ locally. Ir's only drawback is that it is a 2wd. I was curious to know if it was a major pain to convert over to 4wd? I already searched the forum, couldn't find any related threads, so if you know of some let me know.
What I am interested in knowing...
Do I need a new trans or will a 231 T-case bolt up?
Do I have to cut anything to mount the 2H-4H-4L selector lever, or do I just have to remove a plate and mount it up?
Do I have to move the stock Cross-member in the 2wd, or is it in the same position as the 4wd models?
Is there anything else I am missing here that I need to look at also?
Thank you for the help.
Matt
Matt
