2wd beam.... up and coming project.
DirtBound
Corona CA
this is the rendering i have so far of my 2wd beam, im keeping the stock lower and upper link locations. adding trusses, gussets to the spindles, and shock mounts on the lower links. anything anyone would suggest i do differently???
Test-fit before you final-weld that top truss in. It might interfere with the oil pan.
Run the bottom truss clear out to, and weld to the inner "C"
fit a gusset to the top of the "C" down to the tube.
c?
