297 Shafts, complete with hubs
hjeepxj
#OCDINK
Denver, CO
Came out of a 91+, w/abs, so they have the ABS tone ring, and I can get that pressed off if you'd like, no charge.
They take a x297 ujoint, so it is an upgrade to anyone with the 260 ujoint, and you can even install an x760 ujoint, making it very heavy duty, same ujoints a D44 uses...
They include the hub, on both sides, the hubs, shafts, and ujoints are all in good condition.
They are both NON-Disco.
150$+ 10$ shipping
Bttt
XJONABUDGET said:
Man seems a little steep. I will give $75 shipped.
:huh: For BOTH shafts WIH HUBS??? nice try...
I just sold a set of used hubs alone for $65!
This is a nice deal!
This is a good deal. I bought some spare shafts and joints from Ary (Safari Ary on Naxja) more than a year ago, probably more than two and paid a little bit more I believe. So in other words a good deal--------Kyle
They're sold!
(Don't worry Justin, I just forgot about this post and just saw it, theyre still yours...;) :) :cheers: )
Weasel said:
So what do I need to put these into a Disco axle? Seal wise I mean, I can hadle the cover plate.
Well, since these shafts are gone, I'll still give you teh info on the swap...:D
All you have to do, is take all of the old stuff out, remove the carrier and put in a new seal beside the carrier, the seal # is 11771, and you don't have to worry about the shims with the carrier, they are inboard if the bearings. Then you put it all back together and fab a plate to go over the hole, or just plug the old vacuum housing...
Any more Q's feel free to PM...
