2008 34ft bumper pull trailer
macgyvr
NAXJA Member #120
NE Indiana
2008 Sweet River Farm's 2 car 34ft trailer for sale.
It was used on one trip to Moab, Utah in Oct 2008 and approximately 8 trips from Fort Wayne, IN to the Badlands.
The trailer has about 7000 miles on it and is still practically brand new.
This is a 14K lb trailer with 2-7k lb axles.
The trailer empty weighs 4700lbs, so you have 9300 pounds to load on it.
Standard Equipment:
GVWR: 14,000 lb. GVWR
Axles: (2) 7,000 lb. Axles with Electric Brakes
(4” Drop Axles)
Easy to Lubricate Hubs
Brakes: Electric Brakes on Both Axles (All 4 Wheels)
Frame: 8” Channel Frame with 8” Channel Wrap Around Tongue
Stake Pockets Down Both Sides of Trailer
Headache Bar (Front Rail)
Deck: Full Metal 1/8” Diamond Treadplate Deck
4 “D” Rings on Floor of Trailer
82” Between the Fenders
Overall Width 102”
4’ Dove Tail (drops approximately 4”)
Cross Members: 3” channel on 18” Centers
Fenders: Removable Heavy Duty Treadplate Fenders with Center Knee Brace
Tires: 16” “E” Range Trailer Tires - 8 Lug - (ST235/80R16)
Jack: 10,000 lb. Jack
LED Lights (Everywhere) & Safety Equipment:
LED Tail Lights with Steel Guards
LED 3-Light Bar in Rear Center
LED Side Marker Lights
Fender Flares with LED Lights Front & Rear
Lighted License Plate Bracket
7 pin RV Plug with Sealed Lighting Harness
D.O.T. Reflective Tape
Safety Break-Away Kit with Battery
Safety Chains
Coupler: Adjustable 2 5/16” Hitch Ball Receiver
Ramps: Adjustable 6’ – 2” Tubular Steel Treadplate Covered Rear Slide In Ramps with Latches
Paint: Primed & Painted Top and Bottom
This trailer will easily tow with 2 xjs or an mj and an xj, or you might be able to squeze 3 tjs if you watch the weight. I towed it with my 2500 Megacab without any issues, it also towed two XJ's loaded both ways to Moab and got 11 mpg behind an 04 F250. I averaged 9 to 10 with my cummins dodge. It pulls very well with no sway. It offers the same predictability that you are used to with your smaller call trailers.
Brand new this trailer will cost $6095.
It will hold loan value as well if you are thinking about getting a loan for it.
$5000 OBO.
Trailer located in Fort Wayne, IN.
Will also come with a same size spare, and for the right price I may be inclinded to throw in my weight distribution hitch.
I am selling because I'm looking to move to an RV as a tow rig and the trailer is too long to keep me under the 65ft length laws.
These first photos are when I purchased it a little over a year ago. The only difference between the first photos and now is that I put a toolbox on the front of the trailer to haul stuff. You can see the toolbox in the next to last picture, which was taken the last time I used it a couple of weeks ago.
mac 'spilt fuel and haul your buddies jeep' gyvr
This trailer tows very well and has all the goodies.
My F250 is an '05 SRW and with a WD hitch, it did not sway or upset the suspension.
Red 'took it to moab and back' heep
