- Near Rochester NY
Pulled the oil pan last night, found a few decent little chunks of metal. also a crack where the oil pump bolts on, the one whole flange is completely cracked being held up still with gasket.
There is a problem with the newer oil pumps not fitting flat to the block. This has been reported here and over on the strokers forum, Although the only reference I can find here (see post #7) http://www.naxja.org/forum/showthread.php?t=1042375
Here it is, complete with pictures from the strokers forum:
http://www.jeepstrokers.com/forum/viewtopic.php?f=34&t=2671
When I rebuild my 2000 engine, I had this problem. Only about 1/16" at the corner of one mount was sitting up above the milled surface. This is not obvious; you have to look closely. I chose to grind the corner off the new pump, since the engine was already clean and assembled. This may have caused your original pump casting to break. At any case, I recommend you inspect the pump fitting very closely before closing the pan up.
