2001 Power window/lock doors
turdles
Atlanta, Ga
I am about to take the doors off my 2001XJ with power windows/locks and speakers and was going to buy a disconnect so that i could just disconnect the wires like a ZJ does. Does anyone know how many wires are going into the dooor?
I have a 2000 with power doors, windows, and mirrors. Last time I had to take off a door panel and work on them I didn't count, but between the speakers and everything else there are at least 15 seperate wires on the drivers side. The other doors aren't so bad.
In my 98 there are alot of wires, but there are only 3 wiring harness. You do not have to take the door apart to disconnect. if you take the kick pannal out you should see the 3 harnesses. Hope this helps
