What is the actual purpose of the brake shield on the front disk brakes? Is there any danger in leaving it off? Have any of you taken it off, if so did you encounter any problems with it off?
Thanks,
Bill
My daughter went tearing things up in my 96 XJ and got a small peanut sized pebble stuck between the shield and the rotor, that thing made a god awful screech. I took that one off (haven't got to the other), but I'm wondering are yall putting in a washer to take up the room from not having the shield?
I removed mine when I had the 30 in there. Never had issues. Don't put any washers or anything in there. Don't grease the crap out of your joints or wipe any excess off to keep it off the rotor.
As stated previously, they are there to keep debris from getting stuck in the brakes. Although they often cause that exact problem. In my years as an auto tech, I've seen many trucks roll in both with and without them. Neither way showed detrimental wear.
Short story...run em...don't run em...It don't make much of a difference.
