In theory, yes, a thrust angle alignment is better. The kicker to this, though, is that on an XJ, there is no (built-in) way to adjust the position of the rear axle relative to the chassis so if you find the axle out of alignment with the chassis, you are kinda stuck.
It's not like you have control arms with adjustable bolts/slots, like seen on some coil sprung axles.
