2 inch budget boost 245/75/16 or 265/70/16
b_palmer22
Military
Hey guys, I've got a 2000 XJ with a coil spring spacer and a shackle with some aftermarket upcountry leafs. I'm running TJ moab rims with the stock 245/75/16 MTR's. Theyre getting a bit beat and have zero siping so I'm looking to upgrade to a set of Duratrac's for this shitty NE weather. I dont get any rub with the stock 245/75's. I've also got a set of zj v8 springs i've been thinking about slapping in. If i do the zj springs and a set of WJ LCA's can i clear the 265/70/16's with out major trimming/rubbing? Or should i just stick with the 245's? The 265/70's are about 10 bucks cheaper for whatever reason. Thanks!!
I'd stick with the 245s having run that size lift and tires.
