2 cat conv, steering shaft , d44 high steer spacer and a rag joint for a sagniaw box
blondejoncherokee
sacramento
Cats are in good shape.
20$ each obo or beer
Sterring shaft is 20$ obo or beer
Free high steer spacer
Free rag joint. Fits a xj box. If youre getting custom and crazy.
The rag joint is actually meant for a j20 FYI. know anyone with a j20?
2 tapped for hudro 4 bolt big bore boxes.
One has a broken nub on the spool valve.
One has a sized bearing in the pitman shaft
One is a big bore j20 box
One is a big bore agr box.
Both are in pieces.
Its sad i ruined 2 perfectly fine and expensive as hell boxes. Lares , agr, psc etc can rebuild them.
20$ for both. Or best offer or beer
Are the cats both renix or HO?
Not sure . Ill try to find numbers. Saved both of these off part outnrigs years ago. Both seem to be in good shape.
Piles of steering boxes. I can put em back together if you want
Free security lug nuts with proper security socket. Enough to do an XJ.
Dibs on steering shaft?
Yep its yours.
It was my spare trail spare after having a trail spare for both the MJ and the XJ...
the XJ has a 200$ borgeson shaft so....
Boxes pending sale to jakes Chad.
Cats were good. I was keeping them for smogging my rig, but when it didnt pass, I did not bother using one of these, I did my usual Buckshot approach to issues and replaced every possible thing making it better than ever. You can see right through both of them and one used to always pass with no issues.
Ill do 20$ or offer on the pair.
I still have like 4 boxes of new thunderbird brake calipers for the front, and a bunch of alternators. and just threw away the check k20 calipers and almost new centric premium pads that almost killed me....
The alternators oe? Could use a good 90+ amp alt for my MJ. It was factory non ac. So, I'm guessing it just has the 60 amp
steering boxes are gone.
knocking the 2 cat converters down to 10$ for the pair... both are in killer shape...
free renix alternator - great trail spare.
the back bearing shot out. good for a core or to take to a rebuilder.
gotta take all the lug nuts since there is only 1 socket for em.
Ill split the lugs with you Sam. I have one of those lug sockets already.
