All prices are OBO. All of this stuff came off of an 89. I have pics of everything so just ask and I will post them. I am willing to ship if you pay for shipping. I can do paypal but prefer cash.
I work in Anaheim and live in Corona so that is where everything is located.
For the people new to XJ's, all RE parts are Rubicon Express suspension parts.
-RE1300 3 1/2" Front Coil Springs: $100 for the set.
-RE1463 3 1/2" rear leaf springs: $150 for the set. 1 spring sags about 1-1 1/2" more than the other. I can get pics of them sitting on the ground and what they looked like installed on my jeep.
-RE1140 Gen2 Quick disconnects: $60
-RE1600 adjustable track bar: $80
-RE3700 fixed lower control arms: $100 for the set. I have a set of new rubicon bushings I will throw in.
-RE (I don't know the part number) fixed upper control arms: $80. I have a set of new bushings I will throw in.
-RE15151 18" Rear stainless steel brake line: $30
-RE1550 22" front stainless steel brake lines: $60 for the set
-RE2120 3/4" transfer case drop: $10
-RE1380 2" front bump stops: $20 for the set
-OEM underhood light: free
-3/4 in spacers for front springs: $5
-AJ Offroad super rock rails: $180 for the set
-Waggy Tail Lights: $40 for the set
-D30 axle shafts: $80 - carried as trail spares. Smaller 260 u-joints with new Spicer u-joints installed
-18" (possible 16" but I believe it is 18")CREE LED flood light bar with adjustable mounting brackets: $50
-Zentec H4 5000K HID lights: $60. I bought these from a guy on here (Tony was his name I believe) and never installed them. Just buy some housings and you will have HID head lights.
-Custom4x4fabrication.com front tow hook. Drivers side only. new with all hardware. Powdercoated: $30
-"highlift" style jack. Old school. 48". works like a champ: $40
-4 Spicer 5-153x u-joints. brand new in boxes: $10 ea
-2 Alloy USA grande 297x/760 u-joints, new in boxes p/n 11500: $25 ea
-Crown Automotive Coolant bottle and cap p/n J0758977K. This is a quality bottle not one of those cheap ebay bottles that blow up like a ballon once it gets pressurized: $20
-Cobra 19D IV CB: $20
-Firestik II CB antenna 36": $15
-2"receiver mounted d-ring shackle with lock and 2 keys: $25
-Goodyear Gatorback Poly-V serpentine belt,p/n 4061025: $15
-Napa p/n CSS980 crankshaft position sensor, new in box: $25
-Napa p/n 2-19111 throttle position sensor, new in box: $40
-Napa p/n 2-26422 EGR valve and gasket, new in box: $50
-P/N 7151365, 7151366 & 7151367 OEM vacuum hoses, bought from Napa: $40 for the set
-Crown Automotive p/n 4006698K driveshaft u-joint straps, new in bags: 2 for $5
-Crown Automotive p/n JA000490 driveshaft u-joint u bolt straps for those looking to convert: 4 @ $5 each
-OTC p/n 7249 3in1 ball joint, u-joint & brake anchor pin service set: $75. used once. Makes changing D30 ball joints a breeze.
-Stinger p/n 4513 16" 2 piece heavy duty snap ring plyers: $60. Great for anyone who works on transmissions.
-Harbor freight transmission jack, p/n 39178, 450lb: $40
-Harbor frieght 3in1 ball joint, u-joint & brake anchor pin service set: $30
-Craftsman 3/8in drive torque wrench 10-75 ft:lbs: $20
-Craftsman 1/4in drive torque wrench: $20 Not exactly sure of the limits but I will check if you are interested.
-262 page "High Sierra SUV Trails Volume II The Western Slope" book by Roger Mitchell: $10
-Laminated Offroad map set, 15 different maps: $25 example maps below
