pancake
- Seattle, WA
I went to Napa and they mentioned two different part #'s for the joints. They gave one number (forgot - sorry) for the double cardan joint on the front driveshaft and 5-153X for (x1) front driveshaft and (x2) rear driveshaft. Someone else on Naxja mentioned I just need (x5) of the 5-153X joints. I guess the only difference is that the two for the double cardan joint have the grease fitting on one of the end caps instead of the fitting on the spider itself. Those two different joints are $25 each instead of $12 each!!!
Can someone help clarify? Also, I should replace the "Ball Centering Kit" while I'm in there correct? Is this a fairly easy job? Thanks!!!!
Happy New Year!!!!!!!!!!!!
