1997 Jeep Cherokee part out
updated 2/5
Jeep Cherokee and Grand Cherokee parts.
D30 axle shafts
-All Dana 30 spicer stock shafts and all large ujoint stock unless noted (shafts in pics):
-long side shaft no ujoint - $30
-outer - $20
-short side complete SMALL UJOINT - $25
Cherokee (XJ) parts:
91-01 2- mechanical fan/w clutch - $20 each
2- auto flex plate (91-01) - $15 ea
radiator overflow - $15
Various (91-01) IAC, TPS - $10 each
91-01 Motor mounts 4.0 - $10 set
91-01 Tranny mount (auto) - $10
Driveshaft rear (97-01 auto 242 tcase)- $30
1996 Aw-4 4sp auto transmission - $150
84-01 Steering box spacer - $15
84-01 Steering box - $40
91-01 Front calipers/pads/rotors $40 side or $70 for both
84-86 Front hubs - $20 each or $30 pair
97-01 Hood (white) - $85
97-01 cowl (white) - $15
97-01 Year old fuel pump - $50
97-01 Gas tank - $30
97-01 Gas tank straps w/all hardware - $20
97-01 Interior door panels - w/ power switches $25 each (will bundle)
97-01 Window regulators - $15 ea(drivers front passenger, rear passenger/driver)
84-01 quarter rear windows - $10 each (3 sets)
84-01 rear door window pass side - $20
97-01 interior switch panel w/rear defrost - $20
97-01 transfer case bezel np242 - $30
97-01 Wiper regulator - $15
84-01 Wiper arms with blades - $10 both
84-01 Front sway bar (newer poly bushings) - $20
Front links $10
97-01 HVAC blower with cage - $15
2- brake booster Master cylinder w/reservoir - $25 (96 and 97)
91-01 transmission/tcase cross member (fits automatic)- $40
97-01 Good steering column with key, wheel with cruise, is worn, clock spring got cut. - $50
Jeep Grand Cherokee (ZJ)
1996-98 drivers side air bag- $50
1993-98 Stock full size spare tire cover (dark gray)
1996-98 driver's window master power window switch panel- $30
mac 'just a few things left' gyvr
Got a 97+ left rear flare?
I think I do have a drivers rear flare left.
mac 'was hit on a pass rear' gyvr
I'll look at the fuel pump today to see brand.
Still got the tank bolts and straps.
mac 'will ship about anything' gyvr
Awesome. I'll try to do a good walk around and see what else I need. I know I need a RR flare mount piece (the front metal bit) but you said yours was hit there too? Is your interior agate/grey? If so I'll check all the interior bits.
Sent from my 2PS64 using Tapatalk
I don't think I have the mount bits, the interior was gray and I have a few pieces left.
mac 'let me know and I'll see what I got left' gyvr
OK, all I've come up with is:
- trim on floor at bottom of hatch opening
- grey spare tire cover
- driver's seat that doesn't suck (yeah, I doubt you'll be shipping that)
LMK about FP
i may have a spare tire cover but i dont have the other stuff, i'll look
i forgot about fp i'll let you know
mac 'busy week' gyvr
Don't see a spare tire cover.
Fuel pump
mac 'let me know' gyvr
OK I'll pass on the FP just because I've heard bad things about anything but Bosch, if I'm going to do all that work I don't want to do it again
How about a rear dome light lens? Just noticed today mine is missing. Don't know how I never saw that before, but I was pulling one of the rear speakers out and hey, whaddaya know.
keep forgetting to check the dome lens
mac 'I might have it on the speaker bar' gyvr
