Updated 2/18
https://fortwayne.craigslist.org/pts/6008499239.html
Jeep Cherokee and Grand Cherokee parts.
D30 axle shafts
-All Dana 30 spicer stock shafts and all large ujoint stock unless noted (shafts in pics):
-long side shaft no ujoint - $30
-outer - $20
-short side complete SMALL UJOINT - $25
Cherokee (XJ) parts:
91-01 2- mechanical fan/w clutch - $20 each
2- auto flex plate (91-01) - $15 ea
radiator overflow - $15
Various (91-01) IAC, TPS - $10 each
91-01 Motor mounts 4.0 - $10 set
91-01 Tranny mount (auto) - $10
Driveshaft rear (97-01 auto 242 tcase)- $30
1996 Aw-4 4sp auto transmission - $150
84-01 Steering box spacer - $15
84-01 Steering box - $40
91-01 Front calipers/pads/rotors $40 side or $70 for both
97-01 Hood (white) - $85
97-01 cowl (white) - $15
97-01 Year old fuel pump - $50
97-01 Gas tank straps w/all hardware - $20
97-01 Interior door panels - w/ power switches $25 each (will bundle)
97-01 Window regulators - $15 ea(drivers front passenger, rear passenger/driver)
84-01 quarter rear windows - $10 each (3 sets)
84-01 rear door window pass side - $20
97-01 interior switch panel w/rear defrost - $20
97-01 Wiper regulator - $15
84-01 Wiper arms with blades - $10 both
84-01 Front sway bar (newer poly bushings) - $20
Front links $10
97-01 HVAC blower with cage - $15
2- brake booster Master cylinder w/reservoir - $25 (96 and 97)
91-01 transmission/tcase cross member (fits automatic)- $40
97-01 Good steering column with key, wheel with cruise, is worn, clock spring got cut. - $50
Jeep Grand Cherokee (ZJ)
1996-98 drivers side air bag- $50
1996-98 driver's window master power window switch panel- $30
mac 'WF is coming! Let's deal!' gyvr
