1995 4.0l cherokee emissions HC idle fail
hansshanks
nampa idaho
Had to run my sons 95 Cherokee 4.0 through the emissions tester today here in Boise Idaho. It failed one category at idle..
test results...
2500 rpm test standard test report
O2: 1.0
CO(%) (less than or equal) 1.20 0.63 pass
HC(PPM):(less than or equal) 220 212 pass
Dilution CO+CO2(%): 6.0 14.43
RPM: 2500+/- 500 2381
Idle test standard test report
O2: 3.5
CO(%) (less than or equal) 1.20 0.64 pass
HC(PPM):(less than or equal) 220 422 fail
Dilution CO+CO2(%): 6.0 12.73
RPM: 775+/- 425 726
After failing, I went home and threw in the set of autolite platinum plugs I had previously purchased since I already had them. put a half can of seafoam threw the brake booster hose since I was already under the hood.. then went and drove it for a half hour and went and retested and the failed HC went down from 422 to 419.
Now that I think about it. My sons jeep does physically have a cat under it. but the cat is hollow because it blew its guts into the muffler last spring. So at the time I didn't spend the money on a new cat. just put a new muffler under it. It also sounds like it has a exhaust leak some where. haven't had a chance to dig into it further yet. It runs good and stays cool. I also have a set of neon injectors that I had intended to swap into it.
Any suggestions to address the issue.
you have a hollowed out cat, didnt pass emissions, and youre looking for suggestions on what to do? Forget replacing that cat, you just need a new distributor cap
