1994 YJ, Speed Offroad Full Modified, Jakarta INDONESIA
Re: 1994 YJ, Speed Offroad Full Modified, Albins Close Ratio Gears
jjvande said:
ALBINS Gear Close Ratio installed in AX-15 5 Speed Transmission (5th speed is 1:1 ratio)
more on this please
http://www.albinsgear.com.au/
They have been making AX-15 Gearset for our Speed Off Road.
We have discussed with them what they need, and they custom made close ratio gearset for us.
In Indonesia, ALBINS Gears can be purchased direct from KSNUSA MOTORSPORT.
By having this "CUSTOM MADE" gears, we would able to utilize the 1st gear much longer compared to the original 1st gear which would only be used on starting line only.
Also by having close ratio gearset, you would NOT LOOSE or DROP the engine rpm significant, because the gear ratio of each gear is very close, compare to the drop or ratio of the original gear.
Wiring - InHouse, Custom Wiring
Control Panel - Painless Wiring
Electrical Cut-Off Switch - Hella (Ignition and Fuel)
Instrument Gauge - Autometer
Emergency Brake - Rally Hydraulic Emergency Brake
