Lordhelemt
- Arlington
Did a 4.0 swap into a CJ from a 94 XJ. The project is pretty much buttoned up but I need to build a down pipe from the exhaust manifold. I briefly thought about cutting and using the pipe from the XJ but it has too many bends to really get a good transition to the cat and out the back (running the exhaust down the drivers side).
I think it will be pretty simple to build something that would work with a piece of flanged and 45degree pipe but I'm not sure about the flanged piece that bolts to the exhaust manifold (stock). Will a socket flange work for the piece that ties into the manifold or do I need something different?
