Doors all lock like you would expect of them; fast, normal.
Front passenger door unlocks slow, the rest including rear hatch do not unlock. Doesn't matter which switch I press. Doesn't matter if the Jeep is running or not.
I've been testing all that I can think of. Tried new relays, no change. 12.5v to domes/vanity/courtesy/glove box lights/RKE, 12.5v from the fuse block to the light green wire at both relays. Windows roll up and down fine, so it's probably not the 30amp circuit breaker.
For some reason, there's a huge voltage drop in the unlock relay/circuit. The relay gets 12.5v in, and puts 5v out when I hit the switch, not nearly enough to power a lock actuator. The voltage drop eventually goes down to 0.6v at the rear hatch actuator.
I've tested the entire circuit for resistance. It's around 85-90ohms, which from what I've read around is considered normal? I'm still not entirely sure.
I checked all the door hinge boots and there aren't any broken wires as far as I can tell.
I haven't changed anything related to any electrical stuff. This just happened out of nowhere. I noticed this happened after I replaced the headliner so I'm wondering if I bumped or broke something along the line.
I don't know what else I can test. Any input would be greatly appreciated.
Here's the wiring diagram.
