DetroitStyle
- Detroit
I missed the later down post where Kim mentioned having a new exhaust with no catalytic... so I guess that's not the issue this time.A clogged Cat converter would give problems all the time.
He said his runs fine at a cold start up.
A clogged cat converter would always, at all temperatures restrict exhaust flow and cause the engine to run rough as you increase engine speed with more gas, more throttle. And depending on how bad the restriction is from a clogged Cat converter it might or might not run rough at idle.
A broken, internal honey comb, loose guts in a Cat converter would usually rattle as you give it gas, and would randomly bog down on acceleration as the guts rotated around into different positions, blocking and unblocking exhaust flow.
However, when my catalytic converter was plugged on my Z28, it would behave exactly as listed. It would start up fine first thing in the morning and run great for about 5-10 minutes, then slowly but surely start bogging down, etc. It actually felt like the trans was slipping a bit.
I would shut it off, wait 15 minutes and it would run fine for a minute or two, then act up again. Let it cool down fully and it was fine for 10 minutes. Rinse and repeat.
Finally I cut a slot in front of the cat and it got a lot louder, but ran great again. Replaced it with an offroad pipe and all was good again.
