Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Yes that is that right part location for the TPS. It has two separate connectors, one flat, one square. Each has a 5 volt input wire, a ground wire, and TPS output/return. The square one (four pin holes, 3 wires) is for the TCU, it goes from, .2 volts to about 4 volts, from idle to WOT, IIRC. The ECU side is a flat 3 pin connector, 3 wires that is connected the ECU, engine computer. It is .83 volts at idle, and about 4.3 volts at WOT (IIRC). Also be sure to test the ground wire on each (should be less than 1 ohm). Both of mine were terrible, I had to run new ground wires from both sides directly to the battery (-) post on mine.
PM me with your email address for more.
