1989 XJ 4.0 AW4 etc
iluv83vettes
Houston
I need my Jeep gone.
I'm not going to have a place to keep and and would like someone who would use it more than me to have it.
Has:
-dana 30 converted to one piece shafts with a spare set of shafts and the original two piece shafts. welded spiders
-dana 35 new brakes. Just put on a new yoke with the u-bolts instead of the straps
-3 inch pro comp lift
-extended shackles
-have coil spacers and drop brackets but they are not installed right now
-trimmed fenders. folded the rear.
-heavy duty steering tie rod etc
-weld racing aluminum 15x10 rims
-removable doors
-spare front doors that are stripped that I never made into half doors
-spare front drive shaft
-2 spare rear shafts need u-joints replaced that I have in boxes so I -wouldn't lose the caps
-Rustys HD trac bar with an extra bar. (the first bar they sent me was too long so they sent me another one)
-spare stock trac bar and mount
-stripped carpet and put bed liner inside
-front speakers mount on dash so doors remove easier
-has a sub and amp but its not working right now. probably just some wiring stuff
-replaced motor mounts not too long ago
-cb radio, but needs a new antenna
-waterproof neoprene seat covers
the bad
no bumpers
tires should probably be replaced (3 bfg mud 33x12.50, 1 pretty bald 33x12.50 that I threw on there after splitting the other m/t at ROM last year)
welded front diff makes it hard to drive on street (I haven't in a year since I bought my F-250)
tags are out (the only thing that it didn't pass inspection last time was e-brake because I had a 44 in the rear and put discs on it and never bothered with one)
I won first place last year at ROM with it, so it is very capable
I can email or text pictures just email me or text me and I will reply in that method
281-435-5607
[email protected]
I'm sure there is more stuff that I have forgotten
Located in College Station with a clear blue title
asking $2000 negotiable
I'll trailer it to my place and take it off your hands ;) :)
Good luck with the sale!
Be sure and post if you part it out!
