1" Lift Motor Mounts ?
CobraMarty
Has anyone used these? Do they fit? Does anything hit?
I couldn't get mine in place. bellhousing hit firewall. then again my t-case crossmember may have been bent up about an inch or so too.
I was going to do it for trussed axle clearance at full bump.
Why would anyone in an XJ need those?
i figured getting my oil pan an inch further from my axle would be a good thing seeing that they have smashed together in the past, and help level my driveline with my 1" raised t-case crossmember.
In a 'street' 2WD which is lowered, the oil pan will hit the axle tube when lowered way down. 1" lift motor mounts would give 1" more lowering before hitting. Instead of 'sectioning' the axle tube and notch/lower the center tube section.
