04 TJ Clutch or Slave Cylinder went yesterday
XJOutsider
Landenberg, PA
I have an 04 Sahara my dd with the 4.0L and the NV3500 5 speed Trans. I know it is not a XJ but really need help.On the way to the store yesterday I started feeling a vibration in the clutch pedal When depressing it to shift. So I turned off the Radio to listen. With the clutch pushed in the there was a funny clanging rattling noise. A little further down the Road the Trans did not want to shift into Gear well. On the way home form the store the jeep continued the same symptoms. I crossed the last stop sign on the way to my house and the clanging got worse and you could smell something burning. I pulled over and crawled under the jeep and there was smoke coming out of the bottom of the bell housing where the trans connected to the bell housing. I managed to get the jeep Stated again. I waited till no traffic was coming and then eased the trans into second Gear very carefully. I got it into gear with out Grinding and limped it the 5 miles to the house. This was my last choice I call 6 Towing companies and got no one I was angry.
Now I need to figure out wither it is the clutch or the clutch slave cylinder so I can get parts and fix it.
Let me know your thoughts
Thanks
James
