crushtheogre
- CT
Hi everyone I'm building my 1st XJ and it's very cool. I've done a few CJs, a TJ, ZJ, WJ, and a few F350s.
2 very experienced friends of mine are doing most of the work as I'm out of commision for a while after some recent surgery but here's the build;
2001 4dr
newer 4.5L stroker engine(1993 YJ 4.0L HO block (125K miles on it, zero cylinder run out), pistons, head, stock cam for now
-1976 258/4.2L crank/rods (54K miles)
-new cap, rotor, plugs, wires
-all new gaskets and seals throughout
-new main and connecting rod bearings
-crankshaft spacer for the serpentine harmonic balancer
-new water pump (Advance Auto)
-new piston rings
-honed cylinders
-painted really fast lime green)
5.5" lift, gonna be all spring lift
33" AT BFG, I might do some 35" TRXUS or MTZs
Arb bumper(coming up from NJ) hopefully,
Warn 9500 winch
8.8 rear 4.10s w/locker
HP30 4.10s w/ LS front
Longarming the front
Sliders tied into unibody stiffeners
full roof safari rack
a couple Hella front lights
Skids? What should we protect and what's good?
I got a few questins for you guys, search didn't help much;
Can I use a old style header (91-98) on it? Is the connector between the s-pipe the only difference? Will the newer intake interfer? I know the newer exhaust manifolds are 2 piece and a real PIA!!!We're doing the whole exhaust at 2.5" Mandral bent.
Do I need a adj MAP sensor and 24lb injectors? The 4.5 came out of a YJ and ripped pretty hard in it. In this XJ with 3.55s and 33s it spins them at 40mph already!
I'll be adding a 62mm TB, spacer and big stupid cone intake filter.
Can 5.5" lift clear 35s with some aftermarket flares?
Do the 01s come with electric fans already or should I add it?
Thank you
Paul
2001 4dr
-new piston rings
-honed cylinders
Warn 9500 winch
Thank you
Paul
