- Lafayette, CA
I am looking into building my own adjustable trackbar for my front D44.
This axle will have high steer, and hopefully a trackbar that ends somewhere by the inner C.
For those of you that have done your own adjustable track bar, what ends are you using? JJs? Heims? Bushings? Combination?
I found this JJ at Poly:
http://polyperformance.com/shop/Forged-Johnny-Joints-p-388.html
Adjustable, and uses a 9/16'' bolt.
Im now stuck on the other side. I would try to stay away from a bushing, so seems to leave me using another JJ, or a RE joint.
http://polyperformance.com/shop/Johnny-Joints-p-16765.html
JJ 7/16'' bolt
http://polyperformance.com/shop/Super-Flex-Assembly-XJ-MJ-ZJ-TJ-WJ-p-1990.html
RE joint, uses a 10mm or ~.39''
Is there a difference between any of these options? Any input would be great.
JJ 7/16'' bolt
