Old August 4th, 2008, 09:04
Mesh's Avatar
Mesh Mesh is offline
NAXJA Forum Supporter
AW4 Teardown & Rebuild (Lots of Pics)
The kit Iím using is the ATP RM30 which contains friction, steels, gaskets, seals. I also had an ATSG manual to help me along the way; I wouldnít attempt a rebuild without it. This is an ongoing project last time I pulled the engine and rebuilt the transfer case (Link) now itís time for the transmission. Tools used for teardown; snap ring pliers, one pick, two regular screw drivers and a couple sockets. My projects have no budget and the reason for the rebuild is? Donít care.
The AW4 needs servicing like every other transmission in the world itís not a big deal like some may believe. There are a lot of parts, to keep it organized I put each clutch pack in a Ziploc bag and labeled it. When I put it back together I will take one out at a time clean it replace the parts and reassemble back in the case this way Iím only working with a handful of parts at a time. Iíll spend the next couple days cleaning parts and replacing clutch packs and try and keep you guys updated.
Old August 4th, 2008, 09:50
C85D4x4's Avatar
C85D4x4 C85D4x4 is offline
NAXJA Member #1311
Re: AW4 Teardown & Rebuild (Lots of Pics)
Subscribed
Old August 4th, 2008, 09:59
philip_g philip_g is offline
Wow, there's pretty much no way I'd get that thing back together.
Old August 4th, 2008, 10:20
razdrvr's Avatar
razdrvr razdrvr is offline
I didn't even think a brand new tranny would be that clean, much less one needing a rebuild.
Old August 4th, 2008, 10:22
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
X2 on subscribed!
Be careful you don't get any dirt in that clean transmission, LOL!
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old August 4th, 2008, 10:33
jeepcomj's Avatar
jeepcomj jeepcomj is offline
nice...i'm following this one, as I intend to do the same
Stallacrew's Avatar
Stallacrew Stallacrew is offline
So what happens from here?
Its not how fast it will go, its how fast it gets to how fast it will go.
Old August 4th, 2008, 11:24
UNCC_99XJ's Avatar
UNCC_99XJ UNCC_99XJ is offline
Twisted Up
Bad ass dude! Definitely bookmarking this thread!
-Timbo -
-'99 Sport, RE 4.5" and a few other things
-'13 Performance Blue Ford Focus ST. DD & Race Car.
-'17 Ruby Red F150 Lariat. Tow rig and occasional DD
Old August 4th, 2008, 12:31
poorboy_616's Avatar
poorboy_616 poorboy_616 is offline
Subscribed!!!
I have rebuilt a couple TH350's anda TH400, but the AW4 would be a new one for me.....
Old August 4th, 2008, 12:39
tkjeeper's Avatar
tkjeeper tkjeeper is offline
uh...subscribed!
Old August 4th, 2008, 13:23
UNCC_99XJ's Avatar
Twisted Up
Just realized from reading your engine thread that it has 230K on it....was the tranny that clean when you took it apart?
-Timbo -
Old August 4th, 2008, 21:51
Mesh's Avatar
Next clean case with solvent and blow off with compressed air to remove all particles. Then start with the last clutch pack compress remove snap ring remove old friction and steels again clean. then soak new friction plates in transmission fluid and reassemble pack. There is more to it I'll try and take some pictures.
The external case was caked with oil and dirt I started cleaning it with a putty knife. The inside was covered with a black film pictures make it look 10x better. Also the external case needs to be clean before its opened if dirt gets inside and even if you do another cleaning it can cause problems.
Old August 5th, 2008, 00:42
funvtec's Avatar
funvtec funvtec is offline
in
Old August 5th, 2008, 08:51
Mesh's Avatar
So here is the transmission oil pump puller. My R&D team has been working on this tool for months. I didnít make this tool so he said the deal is if you figure it out you can use it.
Hopefully I don't have to work late all this week so I can get started.
Old August 10th, 2008, 23:50
Mesh's Avatar
Sorry about the delay. Finally finished a little more what I have left is one clutch pack, oil pump, valve body, and the overdrive support which the new o-rings are incorrect. I'm stuck until I get the right o-rings.
A couple things I ran into are the first-reverse brake pack did not fall within spec and had to add an extra steel to fix it. Two more packs were the same but I was able to swap some thicker steels to compensate.
Some more pics.
Decided to cut up the XJ .. lots of pics BRUISER Advanced Fabrication and Engineering 101 September 14th, 2011 15:05
96 XJ build (lots of pics) el_roy1985 Modified Tech Discussion 8 November 25th, 2010 19:52
my OBA setup - lots of pics Char-Broil Modified Tech Discussion 31 April 7th, 2009 09:58
Pics of my 88XJ with front leaf springs - help the newb! LOTS of pics, 56k death Goatslayer Modified Tech Discussion 41 December 5th, 2007 21:00
My WinterFest Pics (lots of pics) IntrepidXJ WinterFest 2007 14 March 6th, 2007 10:37
