87xjco
- Denver, CO
Here's my build that i'm in the middle of, I'm doing mine a little different then i've seen any one else set one up for an XJ.
My truck of course is not an XJ, but I bulit it with very similar bracket positions as an XJ, so maybe some of this will apply to XJ builders.
One of my goals with the HP44 is to have a little wider WMS then the Waggy 44 I currently run, this will give me a little more stability and also get my tires outside the exo-cage a little more, maybe then I can get thru situations where my cage hangs up on rocks and the tires are too far inboard to get traction.
The HP44 is 6" wider then my Waggy 44, but this is a little more then I would prefer, i'd like about 3" wider instead.
Also right now I have a slight problem with my driveshaft occasionally rubbing against the exhaust downpipe, and with the yoke being higher on the HP44, that problem might get worse.
So this first diagram shows the current dimensions of the Waggy 44 that is in my truck now. I'd like to get the center of the yoke in relation to the left spring center, to be about a half to an inch less then the current 8.50" dimension. The 47" measurement is center of ball joint to center of ball joint. The 36.50" spring center to center needs to stay the about the same.
This diagram is the stock dimensions of the HP44 that I have. If I center the axle, the yoke to spring center increases .25". That could be a problem. I also don't like being 6 inches wider.
