- Hesperia, Kalifornia
Well I'm just about done with these, will have the rest of it done tomorrow. I could have gone with the bolt on option that causes you to lose some ground clearance, so instead I opted to go with the cut out sheet metal rockers and replace with rec tubing method.
Material used: 2"x4"x3/16" and 1.5" HREW .120 wall
Old rockers cut out..
Measuring for rec tubing size to allow for round tubing slider.
Rec tubing welded in, round tubing slider also welded on.
I still gotta add some cross bracing for the slider, but I'll get to that by the end of the week.
