Remote start help...
krackerjack87
Wichita, KS
I've got everything hooked up and it works.. kind of. The manufacturer is JBS Alert 150R add on remote starter. I can start the jeep by pressing the lock button on the door 3 times but when I go to the factory keyless fob, it doesn't work. i.e. I push the door lock button on the fob and it should start the jeep. I know I have everything hooked up right except that I have type "b" door locks. I hooked up the instant start/stop wire to the lock wire in the door. On their website it shows type b wiring diagram and says that I need a relay. So I went out and got the relay. But I can't figure out what the wires are that are in the diagram.
This is the website for the type 'b' door locks:
http://alertautomotive.com/Alert and Shelby Frequently asked Questions.doc
This is the website for the installation manual:
http://alertautomotive.com/manuals/150AlertInstallManual072104.pdf
Yeah, but shouldn't it start it since it's doing the same thing. It's locking the doors when I push the button on the fob and that's the same thing as pushing the door lock on the door isn't it? I'm confused to why it won't work. They are two different systems but why won't it do the same thing?
Yes, the vehicle attempts to lock everytime I push the key fob lock button. I'm not sure what you mean by pause... and yes you have to press it three times in order for the remote start to engage.
